kekegsm's avatar
kekegsm
Guide
Mar 22, 2017
Migrating Disk from an Readynas Ultra6 (OS6.6.1) to a Readynas Pro6 (OS6.6.1)
Hi   I have a perfect working Ultra 6 with OS 6.6.1 and 3GB RAM. 6x3TB WD Red disk, x-raid. (like raid5) I just bought a Pro 6 (4GB RAM, Q6600 cpu), upgraded now to OS6.6.1 too with a spare disk. ...
  • mdgm-ntgr's avatar
    Mar 22, 2017
    Yes, that should work fine.
    Power down both systems, remove the scratch disk from the Pro 6 and move your disks across (keep the disk order the same).
ProSupport for Business
