Poldek
Mar 03, 2016Guide
Migrating from 2 × 1TB to 1 × 2TB
Hello, for some years already I have ReadyNAS Duo (SPARC aka v1). From the very beginning there are 2 disks of 1TB with X-RAID (redundancy). The time has come to upgrade for more space. So I got one...
- Mar 03, 2016
Yes, I know that putting two 2TB disks would have given me 2TB of disk space with redundancy.
At this stage I don't care for redundancy. Neither I want to buy second 2TB disk.
What I want is to have:
1. all my configuration settings preserved,
2. 2TB disk space
3. ONE disk of 2TB capacity inside my ReadyNAS Duo (SPARC).
The question is: is there a way to get this without manually recreating all configs?
What will happen in that given scenario:
1. ReadyNAS is on with two disks of 1TB synchronized and redundant,
2. I hot remove disk no2,
3. I put new 2TB disk into bay 2,
4. ReadyNAS initiates and synchronizes new drive,
5. When sync is done I hot remove disk 1,
6. I reboot ReadyNAS.
Will it expand to 2TB then?
If it will not expand automatically, will it expand with manually initiated command? If so, how to do it manually?
Poldek
Mar 03, 2016Guide
2. 2TB disk space
lundmilo
Mar 03, 2016Luminary
Poldek wrote:Yes, I know that putting two 2TB disks would have given me 2TB of disk space with redundancy.
2. 2TB disk space
I don't think that will work. AFAIK the NAS will not expand unless both drives are replaced with larger ones. X-RAID doesn't support reducing the number of discs or disc capacity.
If you hotswap your current disc 2 and replace it with a 2 TB disc the NAS will resync. When you remove the disc in bay 1 the NAS wil consider the volume as degraded as there is no longer any redundancy.
I doubt that rebooting the device will change this.
If you want to have the NAS running with just one disc you will have to do a full backup and then do a factory reset with the 2 TB in the NAS (And ONLY this disc). This will wipe all data and settings.
- JennCMar 03, 2016NETGEAR Employee Retired
Hello lundmilo,
Thanks for helping to explain. :)
