Poldek
Mar 03, 2016Guide
Migrating from 2 × 1TB to 1 × 2TB
Hello, for some years already I have ReadyNAS Duo (SPARC aka v1). From the very beginning there are 2 disks of 1TB with X-RAID (redundancy). The time has come to upgrade for more space. So I got one...
- Mar 03, 2016
Yes, I know that putting two 2TB disks would have given me 2TB of disk space with redundancy.
At this stage I don't care for redundancy. Neither I want to buy second 2TB disk.
What I want is to have:
1. all my configuration settings preserved,
2. 2TB disk space
3. ONE disk of 2TB capacity inside my ReadyNAS Duo (SPARC).
The question is: is there a way to get this without manually recreating all configs?
What will happen in that given scenario:
1. ReadyNAS is on with two disks of 1TB synchronized and redundant,
2. I hot remove disk no2,
3. I put new 2TB disk into bay 2,
4. ReadyNAS initiates and synchronizes new drive,
5. When sync is done I hot remove disk 1,
6. I reboot ReadyNAS.
Will it expand to 2TB then?
If it will not expand automatically, will it expand with manually initiated command? If so, how to do it manually?
Poldek
Mar 03, 2016Guide
Ok - so there is no other way for me than factory reset.
Then could you tell me please if:
1. After I made factory reset - is there any difference if I put the 2TB disk (as the ONLY disk in the NAS) into bay 1 or bay 2?
2. I saved not only data, but also settings somewhere else. After factory reset and now ONE 2TB drive I can run RAIDar and have few minutes to choose - what to choose: JBOD or X-RAID? Considering there will be ONE drive in the NAS, probably for long time if not for the rest of the life of this NAS, but there is LITTLE chance that someone will give me good 2TB drive as a gift, I'll not have other option to use it, so I'd put it into the NAS then.
Will there be choice of X-RAID/JBOD at all if there is only ONE disk inside?
3. I try do restore my config from a saved file - will it work with new bigger disk and just ONE disk (JBOD vs. X-RAID)?
JennC
Mar 03, 2016NETGEAR Employee Retired
Hi Poldek,
1. There is no difference whether you use bay 1 or 2.
2. It is up to you if you use XRAID or FlexRAID. XRAID if you are expecting to have an additional disk for the other bay. It is for redundancy and not expansion. Setting up the NAS always starts with volume creation where it asks which RAID you want to use.
3. See page 98 Back Up and Restore Settings in the user manual, it does not matter if you use XRAID or not as long as there is a volume created.
- PoldekMar 03, 2016Guide
I see - thank you very much.
So, another way round...
I remove both old 1TB disks from NAS. I put ONE new 2TB disk into NAS. It is initialised etc. I play with it for some time - I create accounts, put some data on it - I play with this new disk for some time to see how it works. Then I remove this 2 TB disk from the NAS and I put back two old disks into the NAS again. Will everything be the same, as it was before? I mean configs, data? Or the NAS will treat the old disk as new ones and initialise it from the beginning.
- JennCMar 03, 2016NETGEAR Employee Retired
Hello Poldek,
Data and settings are saved to the disk/s. So if you remove the new disk from the chassis and put the old one back in, it should still give you access to the data and still have the same settings, it is safer if you power off the NAS first before removing and inserting any of the disk. Also, make sure to take note which bay the old disk is situated, always insert it to same bay where it has been working.
- StephenBMar 03, 2016Guru - Experienced User
The net here is that to get what you want you need to save the data to external storage (PC internal drive or USB drive), and then do the factory reset with only one drive in place. There is no way around it.
If you choose flexraid, you'll be able to add the 1 TB drive back later on, and have a C volume with 2 TB and a D volume with 1 TB.
