manda
Jun 25, 2012Aspirant
minidlna doesn't start automatically
Hy guys, I've a Readynas NVX+ (x86) with RAIDiator 4.2.21. Since several times I see when I start my NAS, the ReadyDLNA server doesn't start automatically. I tried to upgrade the module with the...
manda
Jul 26, 2012Aspirant
Hi Renaud,
I've already tried that, i've added the command in that script but, still, after reboot, no minidlna process active
nas:~# ps -ef | grep minidlna | grep -v grep
nas:~#
You can check the logfile /var/log/upnp-av.log to see if something is wrong. (Sometimes minidlna doesn't start simply because it tried to bind an IP address which is not yet setup)
I've even created a script called minidlna in /etc/init.d as the post you suggested and added it to rc update-rc.d minidlna defaultsbut nothing, at reboot doesn't start.
If I launch it manually obviously it starts.
Any idea?
Thank you very much,
Alessio
it's due to heavily customisation of netgear
As mdgm said, you could also contact the support, in my case there were unsuccessful to fix my trouble ;)
