Madcat22
Dec 29, 2013Aspirant
Missing setup and browse from raidar and cant access shares
Win 7 and Readynas duo V1 After starting I couldn't access shares anymore. drive failure message and all sorts went on. Took out one of the drives and checked out data via R-Linux and it all seem...
Dec 29, 2013Guru - Experienced User
use \\nasname in the windows explorer address pane (not IE). Or \\nasname\sharename to reach a specific share.
You can also create shortcuts using that convention, and map drive letters using it. Though mapping drive letters makes the NAS vulnerable to cryptolocker.
