eton
Jan 12, 2015Luminary
Monitor rsync daemon?
Is there some way to view what rsync is doing during a backup job when rsync is running as a daemon? Maybe something similar to rsync -v, to monitor what files are being copied.
- markwollGuideI would second that capability.
The current logging is not robust enough for our needs.
Truncated log files are a not acceptable.
A check box for summary vs detailed would be nice for those who don't want the whole thing. - etonLuminaryCLI is fine with me, but of course a GUI version would be really great.
Just found this, rsyncd has a monitor switch:
http://linux-ha.org/doc/man-pages/re-ra-rsyncd.html - etonLuminaryNo help?
Let me rephrase.
I there a way to "connect" to an active rsync process and display what it's doing right now? Similar to -v (or -vv) on non daemon rsync commands. - etonLuminaryFound these methods:
You can do: strace -e open $(ps -o lwp= -LC rsync | sed 's/^/-p/')
To see what it's doing, orlsof -ad3-999 -c rsync
to see what files it currently has opened.
Source: Monitor/Watch running rsync process
More here: View stdout for another pts
But strace and lsof are dependable up on libc6 >= 2.6, so they will not install with apt-get. - abickertonAspirantIf you look at the (truly hideous Perl code) /frontview/bin/backup then you can modify the command that's being executed. I would suggest teeing to a temporary log file.
- etonLuminary
abickerton wrote: If you look at the (truly hideous Perl code) /frontview/bin/backup then you can modify the command that's being executed. I would suggest teeing to a temporary log file.
Thanks abickerton! I've missed that one./frontview/bin/backup
That file might need further scrutiny.
