greg_t
Apr 22, 2020Aspirant
Most file shares not visible from Frontview (Ultra 4 plus, OS 6.10.3)
This afternoon I noticed that Frontview on my Ultra-4 plus server was only displaying shares for "Home Folders" and the 7 shares I have been serving for years were not visible. The shares are mounta...
JohnCM_S
Apr 22, 2020NETGEAR Employee Retired
Hi greg_t,
If you are comfortable in configuring your NAS via SSH. You may use the script provided on this link. This should fix the issue wherein the shares do not appear on the web GUI.
- greg_tApr 23, 2020Aspirant
John,
Thank you for that script. I am very command line savvy so I looked it over and ran it.
It worked superbly. I am very thankful for your noticing my plaintive plea, recognizing the problem and pointing me to that script.
Is there an explanation for what happened to cause the problem in the first place?Thanks again,
Greg
- JohnCM_SApr 25, 2020NETGEAR Employee Retired
Hi greg_t,
It is most likely one of the configs on the NAS got corrupted which caused the issue.
The readynasd keeps a copy of configs in the database but it imports every time at the start of readynasd. What most likely happened is when the NAS rebooted, the readynasd tried reading those config files where it imports from and it had no data on the files, so it has nothing to show. This also means that it can't update the Shares.conf file which contains all the shares, making file explorer show you all the shares that were there before the readynasd configs were emptied
