brettgavin
Feb 12, 2012Tutor
Mount previously created raid via USB
Hi, Please forgive me if this has already been covered, but I didn't find it. I set up my Pro6 the other day with one 2TB disk and planned to add my other, smaller disks later. I didn't realize ...
mdgm-ntgr
Feb 15, 2012NETGEAR Employee Retired
Yes you should be able to use mdadm to stop the RAID
then disconnect it, connect it to the NAS and mount it.
You can then use e.g. "cp" to copy the files across.
mdadm --stop --scan
mdadm --assemble --scan
vgscan
vgchange -ay oldvol
mkdir -p /oldvol
mount /dev/oldvol/oldvol /oldvol
