brettgavin's avatar
Feb 12, 2012
Mount previously created raid via USB
Hi,
Please forgive me if this has already been covered, but I didn't find it.
I set up my Pro6 the other day with one 2TB disk and planned to add my other, smaller disks later. I didn't realize that Xraid2 requires that the smaller disks be the first disks in the volume. So, I offloaded almost 2TB worth of data onto the first disk. I inserted the first of my smaller disks, and the readynas displayed an error about the size of the disk being to small. I pulled the 2TB disk and did a factory reset with one of the small disks in bay 1. I have since recreated the raid with 4 disks (3x500, 1x1000).
Here's what I would like to do:
option A:
either plug the 2TB disk into the Readynas via USB and do a direct file copy from the 2TB to the internal volume;
or
option B:
plug the disk into the computer using ubuntu or knoppix, mount the 2TB, and push it over the network to the readynas.
My questions are:
is option A possible? I don't want it to erase the disk and create a new partition.
if option A isn't going to work, what is the best procedure for accomplishing option B?
Thanks in advance,
Brett
ProSupport for Business
