redpola
Jul 26, 2012Aspirant
Mountain Lion >>> No backups
So, I upgraded to ML, and now my TM icon has the exclamation mark on it. If I try to manually start the backup I'm told the disk isn't available. If I try to select the backup disk in TM prefs I canno...
redpola
Thanks for the response. This is connected wirelessly. It's difficult to get Ethernet to the machine so someone else will have to try that.
My point is; literally nothing has changed but my OS. I backed up to TM, installed ML, and then tried and failed to backup all in the space of an hour.
10.7.X via wireless to Ultra 6 - fine
10.8 via wireless to Ultra 6 - fail
What makes you think that a wired connection will fix the problem?
