redpola
Jul 26, 2012Aspirant
Mountain Lion >>> No backups
So, I upgraded to ML, and now my TM icon has the exclamation mark on it. If I try to manually start the backup I'm told the disk isn't available. If I try to select the backup disk in TM prefs I canno...
redpola
Jul 30, 2012Aspirant
Knakker wrote: Again, I can confirm that redpola's first solution still works for me.
I just had to do 'sudo tmutil setdestination /Volumes/YOUR_BACKUP_VOLUME' once and when I startup/shutdown the NAS or my MBP, TM backups - scheduled or not - are still working fine :-).
The problem with that is that your Mac isn't mounting / unmounting the backup drive. So when you're on, for instance, cafe wifi, you'll see mounting errors.
I just posted a fix which works for me and is "the correct fix" I think. I dunno how it allows AFP logins to work but it does!
Neil.
