TigaSefi
Feb 28, 2012Aspirant
Mountain Lion Preview and ReadyNAS Duo
Hello, I installed Mountain Lion 10.8 on a MacBook Pro (specs incoming if necessary) and I knew from the Lion Upgrade, the NAS was shagged so I was expecting the same thing and initially I thought ...
mdgm-ntgr
Feb 28, 2012NETGEAR Employee Retired
Were things working fine when you were running Lion (10.7)?
What version of RAIDiator firmware is running on the Duo?
On your Mac are you booted into the 64-bit kernel (default) or the 32-bit kernel?
Mountain Lion is in Dev Preview so not everything will necessarily work with it. Having said that it may not be a problem with Mountain Lion and your answers to the questions above may give some clues as to what the problem is. I'm not a member of the Mac Developer Program so I haven't tested it.
