PMDev
Dec 16, 2021Aspirant
moving drive from RND2000 to RND2D
HI Is it possible to move the drives over without data loss? Thanks
- Dec 16, 2021
PMDev wrote:
The RND2000 is a V1 running 4.1. The other is a RN10200 running 6.10.6Thx. RN102 came up when I googled RND2D, but I didn't recall the RN102 being known by that name.
The answer is no, you cannot migrate the disks to the RN102. Paid support can temporarily mount the Duo v1 volume for you, but that is just so you can off-load data. An alternative way to off-load data is to connect disk 1 in the Duo to a Windows PC, and use r-linux for windows. https://www.r-studio.com/free-linux-recovery/
Dec 16, 2021Guru - Experienced User
PMDev wrote:
HI
Thanks
I'm not sure exactly what the RND2D is - do you have another name for it?
Also, we need to know if the RND2000 is a -100 (running 4.1.x firmware) or -200 (running 5.3.x firmware) The -200 will say "Duo v2" on the front panel.
- PMDevDec 16, 2021AspirantThe RND2000 is a V1 running 4.1. The other is a RN10200 running 6.10.6
- StephenBDec 16, 2021Guru - Experienced User
- PMDevDec 16, 2021AspirantThat’s a shame, I’ll probably move it all to an external drive, it gives me a chance to get rid of a load of crap
