WingDog
Jul 21, 2015Guide
MPIO - slow speed
Hello! I have two ReadyNAS6 Pro boxes with the following configs: 1 box RDN6 pro/E7300/4gb/6*2Tb WD CB/4.2.27 FW 2 box RDN6 pro/E5300/2gb/6*2Tb WD CB/6.3.5 FW Other equipment: Juniper EX330...
BrianL2
Jul 22, 2015NETGEAR Employee Retired
Hi Wingdog,
How many active NICs are you using in your ReadyNAS system?
Kind regards,
BrianL
NETGEAR Community
- WingDogJul 22, 2015Guide
Hi BrianL.
Two NICs obviously.
- mdgm-ntgrJul 22, 2015NETGEAR Employee Retired
There are some good tips re MPIO here in the "Configure multiple MPIO sessions to the Target" section
With MPIO the key is have the 2 nics on separate subnets. Otherwise you cannot be sure that layer 2 gets it right- WingDogJul 22, 2015Guide
mdgm wrote:There are some good tips re MPIO here in the "Configure multiple MPIO sessions to the Target" section
With MPIO the key is have the 2 nics on separate subnets. Otherwise you cannot be sure that layer 2 gets it rightit's something new about separate subnets for MPIO =)
I'll check it out.
