WingDog
Jul 21, 2015Guide
MPIO - slow speed
Hello! I have two ReadyNAS6 Pro boxes with the following configs: 1 box RDN6 pro/E7300/4gb/6*2Tb WD CB/4.2.27 FW 2 box RDN6 pro/E5300/2gb/6*2Tb WD CB/6.3.5 FW Other equipment: Juniper EX330...
WingDog
Jul 23, 2015Guide
Hello, mdgm.
Thanks for "the secret key" with two subnets - I've achived ~2*890mbps at READ with RND MPIO. Not so good as other vendors, but acceptable.
I think it will be better to add more MPIO specific information to ReadyNAS OS6 manual (and about supported LB policies too).
PS C:\> C:\SQLIO\sqlio.exe -s900 -kR -frandom -b8 -t8 -o16 -LS -BN D:\testfile.dat
sqlio v1.5.SG
using system counter for latency timings, 2474044 counts per second
8 threads reading for 900 secs from file D:\testfile.dat
using 8KB random IOs
enabling multiple I/Os per thread with 16 outstanding
buffering set to not use file nor disk caches (as is SQL Server)
using current size: 1048576 MB for file: D:\testfile.dat
initialization done
CUMULATIVE DATA:
throughput metrics:
IOs/sec: 25979.92
MBs/sec: 202.96
latency metrics:
Min_Latency(ms): 0
Avg_Latency(ms): 4
Max_Latency(ms): 75
histogram:
ms: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24+
%: 10 9 11 12 11 13 11 9 9 2 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0but what's the mess with WRITE??!!
PS C:\> C:\SQLIO\sqlio.exe -s900 -kW -frandom -b8 -t8 -o16 -LS -BN D:\testfile.dat
sqlio v1.5.SG
8 threads writing for 900 secs to file D:\testfile.dat
initialization done
CUMULATIVE DATA:
throughput metrics:
IOs/sec: 21.26
MBs/sec: 0.16
latency metrics:
Min_Latency(ms): 268
Avg_Latency(ms): 6005
Max_Latency(ms): 13647
histogram:
%: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100
PS C:\>that is unacceptable!
MarcusF
Jul 23, 2015NETGEAR Employee
All MPIO performance is relate dto the client side not the readnas. to see good speed the client must plance the iscsi commands correctly.
The readynas just reponds to the reponse on whichver interface it sees. That is why 2 subnets important because otherwise the readynas will stick to one of the interfaces to send all traffic and so you get no ballancing
But now that you have subnets considered to ReadyNAs there is no extra configuration needed for MPIO. all decison over which interface to send the iscsi commands are on the client side.
I hope this makes sense
I do agreee we could do with some doicumentation in this area but it is not a common configurtation request we have sene but seems it is becoming more popopular.
On the read speed I would think at this point it is limited by interface speed and disk / volume maximum performane not really a readynas specific thing but I could be wrong. So Raid setup and disk performnce should be the limiting factors.
- WingDogJul 23, 2015Guide
That is not complete correct because if I'm using Windows Server as iSCSI target I can use any subnets, including one subnet for all traffic even with 8 NICs both sides.
Unfortunally I also have 4220 box. it's freesing, pausing, lagging and It's absolutly equal to this RND6 pro by FW, but have powerful hardware. So if NTGR presents 4220 as Enterprise (however RND6 pro is MID-Ent for NTGR) manuals MUST have enough explanation of devices logic. And if you presents iSCSI and MPIO - it's must work without some strange config particularly if there is no Vlan Tags and "management" interfaces (or OOB).
This is not correct at all. it's nonsense.
there is no any way to get 20 IOPS and 0MB/sec from one SATA drive.
this is software bug
here is results of the same test at one sata drive (it's second drive at my work PC)
PS C:\Windows\system32> C:\SQLIO\sqlio.exe -s90 -kW -frandom -b8 -t8 -o16 -LS -BN D:\testfile.dat sqlio v1.5.SG using system counter for latency timings, 2728190 counts per second 8 threads writing for 90 secs to file D:\testfile.dat using 8KB random IOs enabling multiple I/Os per thread with 16 outstanding buffering set to not use file nor disk caches (as is SQL Server) using current size: 1048576 MB for file: D:\testfile.dat initialization done CUMULATIVE DATA: throughput metrics: IOs/sec: 135.66 MBs/sec: 1.05 latency metrics: Min_Latency(ms): 0 Avg_Latency(ms): 939 Max_Latency(ms): 1828 histogram: ms: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24+ %: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 99135 IOPS - that is good for one sata drive with such load
- MarcusFJul 23, 2015NETGEAR Employee
I guess you must be running OS6 on the rnd6 because by default they have different OS than RN4220.
I think the 4220 feezing, lagging pausing is a bgger concern. DO you have support case for that becuase there is some many things to discuss there hard to do here.
What happens when no MPIO configured and using single network link? I assume it is all ok.
There is no special MPIO configuration needed on ReadyNAS. To ReadyNAS we are just recieving and transmitting using ISCSI protocol / commands. Just happens with MPIO those are recieved via seperate nics.
From microsoft
"It is not necessary to have multiple subnets for iSCSI multi-pathing, but it's highly recommended, you can guarantee the paths it's going to use. You can use Multipath I/O (MPIO) on iSCSI connection, to deliver a high quality and reliable storage service with failover and load balancing capability."
So maybe we are both right but for me I have always tested anything with MPIO with seperate subnets. Vmware or Windows hypervisors
Of course I can never say we have no bugs but I can say we don't have an open one for MPIO at this time so we are happy to help if can.
RND6 - 6.3.5 (thanks mdgm), RN4220 - 6.2.4 (latest for it)
I HAD support case and while solving it I was need to reformat all 12*4Tb partition. funny?
thanks "Mateusz Janowicz NETGEAR Level 3 Technical Support Engineer" he was able to solve random halting RN4220. now it's only freesing.
maybe, but ~100MB/sec is not enough.
From microsoft
OK, now I have separate subnet. Also I've reformatted X-RAID to RAID0 (6*2Tb SATA drives).
here is results:
PS C:\> C:\SQLIO\sqlio.exe -s90 -kW -frandom -b8 -t8 -o16 -LS -BN D:\testfile.dat sqlio v1.5.SG using system counter for latency timings, 2474044 counts per second 8 threads writing for 90 secs to file D:\testfile.dat using 8KB random IOs enabling multiple I/Os per thread with 16 outstanding buffering set to not use file nor disk caches (as is SQL Server) using current size: 1048576 MB for file: D:\testfile.dat initialization done CUMULATIVE DATA: throughput metrics: IOs/sec: 43.59 MBs/sec: 0.34 latency metrics: Min_Latency(ms): 750 Avg_Latency(ms): 2920 Max_Latency(ms): 6315 histogram: ms: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24+ %: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 100as you can see, even with RAID0 (!!!!) write speed and latency is unacceptable.
read speed equal to X-RAID (raid5) and limited to 2*1gbe.
PS C:\> C:\SQLIO\sqlio.exe -s90 -kR -frandom -b8 -t8 -o16 -LS -BN D:\testfile.dat sqlio v1.5.SG using system counter for latency timings, 2474044 counts per second 8 threads reading for 90 secs from file D:\testfile.dat using 8KB random IOs enabling multiple I/Os per thread with 16 outstanding buffering set to not use file nor disk caches (as is SQL Server) using current size: 1048576 MB for file: D:\testfile.dat initialization done CUMULATIVE DATA: throughput metrics: IOs/sec: 25469.41 MBs/sec: 198.97 latency metrics: Min_Latency(ms): 0 Avg_Latency(ms): 4 Max_Latency(ms): 63 histogram: ms: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24+ %: 12 8 9 12 10 12 10 9 10 2 2 1 1 1 1 0 0 0 0 0 0 0 0 0 0Of course I can never say we have no bugs but I can say we don't have an open one for MPIO at this time so we are happy to help if can.
Hoping for you, because after the third online chat escalltion I lose heart
