pgjscottieuk
Sep 28, 2021Guide
MTU settings XS512EM switch
Hi under port status it says my maximum MTU is 9216 on all ports my RAX120 is set at 1492 my readynas 626x is set at 9000 i have set my mac to 1492 i guess this would create a bottleneck at the switc...
- Sep 29, 2021
You can keep (wherever the adapters and drivers supporting) a high or even maximum Jumbo Frame, typically 9014 on all the wired adapters.
Wireless does not support any Jumbo Frame, so nothing to change from the defaults there, too.
The switch is "just" able to handle frames on "any" size. Thus nothing to change there either.
pgjscottieuk
Sep 28, 2021Guide
What should the MTU be set to on the mac then i also have a Windows 10 htpc on the network what should its MTU be set at
Actually at the moment the mac is connected wirelessly due to some works being carried out in the house but normally it is hard wired into the home network XS512EM
schumaku
Sep 29, 2021Guru - Experienced User
