Adiemus
Nov 26, 2011Aspirant
Much Ado About ReadyNAS Ultra 4
Hi, Does anyone have an estimate of how much time is needed to initialise 4 x 2Tb Hitachi HDD on a ReadyNAS Ultra 4? I had this unit set up and it was working fine. I decided to boot it up to...
Nov 28, 2011Guru - Experienced User
You need all three connected to the switch to start the backup, but once that is done you only need the source and destination connected.
Adiemus wrote: ...To accomplish the backup function, I would need to have both the Ultra 4, the NV+ and my PC hooked up to a switch right?...
Backup is the 6th function down in the left menu.
Adiemus wrote: ...I've to go check up on the backup function in Frontview. I don't remember seeing it...
Network File System. If you google it you can find a fair amount of information.
Adiemus wrote: ...What's NFS by the way?...
