KillerBob
Feb 22, 2012Aspirant
My Book via Ethernet
Hi, Looking for a new backup solution, I found large Ethernet based HDs at a reasonable price and performance. So, if I get one of these, can I connect it via the 2nd Ethernet connection in my Pro,...
KillerBob
Hi mdgm,
Thanks for the answer. The reason for wanting to use the other port was solely for speed, and not for separating it from the rest of my network - I understand the point of being able to access it while it is connected though.
Also thanks for checking up on the MyBook, I couldn't find anywhere they said it could, so I was getting to the same conclusion. I'll probably keep looking for a networked external disc setup then. The portability is important as is the size (I usually hide it away somewhere between backups.)
Bo
Bo
