KillerBob
Feb 22, 2012Aspirant
My Book via Ethernet
Hi, Looking for a new backup solution, I found large Ethernet based HDs at a reasonable price and performance. So, if I get one of these, can I connect it via the 2nd Ethernet connection in my Pro,...
KillerBob
Feb 29, 2012Aspirant
Hi,
Got most of the parts (all except disk no. 2), and followed steps 1-3. I also tried it all out, setting up just a single share. I already set it up as Flex-RAID 0.
Can I go ahead and start using it all, and then simply add disk no. 2 when it gets here (the 3TB 7K3000 is on back-order in Denmark), and it will be added to the single volume I plan to run with? If so, I can start restoring from an external backup while I am waiting for Netgear to fix my Pro Pioneer...
Bo
Bo
