KillerBob
Feb 22, 2012Aspirant
My Book via Ethernet
Hi, Looking for a new backup solution, I found large Ethernet based HDs at a reasonable price and performance. So, if I get one of these, can I connect it via the 2nd Ethernet connection in my Pro,...
mdgm-ntgr
Mar 01, 2012NETGEAR Employee Retired
KillerBob wrote:
Can I go ahead and start using it all, and then simply add disk no. 2 when it gets here (the 3TB 7K3000 is on back-order in Denmark), and it will be added to the single volume I plan to run with?
If you add the disk you can create a second volume D. RAID-0 volumes are not expandable.
Edit: second volume would be D, first volume C.
