KillerBob
Feb 22, 2012Aspirant
My Book via Ethernet
Hi, Looking for a new backup solution, I found large Ethernet based HDs at a reasonable price and performance. So, if I get one of these, can I connect it via the 2nd Ethernet connection in my Pro,...
mdgm-ntgr
Mar 02, 2012NETGEAR Employee Retired
Yes you can choose which volume to create shares on.
However bear in mind that if you wish to use the Time Machine feature enable via Frontview on this NAS it will use volume C.
