h4lt3r
Jan 23, 2013Aspirant
My NV+ died :(
Hi all! I have a problem - my nas is not turning on. I suspect that power supply is dead, so my questions are: 1. Is there any way to buy the power supply that is compatible with ReayNAS NV+ (RND...
mdgm-ntgr
Jan 23, 2013NETGEAR Employee Retired
When did you purchase this NV+? Depending on when you purchased it, it may still be under warranty.
The RND4PSU1 is the PSU for the NV+ (v1)
A standard ATX PSU won't work. It needs to be modified.
