h4lt3r
Jan 23, 2013Aspirant
My NV+ died :(
Hi all! I have a problem - my nas is not turning on. I suspect that power supply is dead, so my questions are: 1. Is there any way to buy the power supply that is compatible with ReayNAS NV+ (RND...
h4lt3r
>When did you purchase this NV+? Depending on when you purchased it, it may still be under warranty.
The problem is than i'm not in the USA so the logistics will be very expensive.
>The RND4PSU1 is the PSU for the NV+ (v1)
Thanks for information!
Ok, one more question - as is i can see, my problem can be also with the motherboard (which is less possible, afaik, but anyway), so is there any way to test the power supply? I mean, kinda "if the power supply is ok, it should give +5V on green wire and should give +12V on red wire if yellow and blue are short circuited", or something like.
