Kalle13
Apr 17, 2016Tutor
My ReadyNAS 214 wont shutdown -> do_exit+8c4
Hello community, I have a problem with my RN214. It`s not shutting down properly. It makes no difference if I do it from the webgui nor with the power bottom. After a few seconds it shows "do_exit...
Kalle13
Apr 18, 2016Tutor
Hi BrianL,
thank you for your reply. I know what you are thinking, but this feature is important to me. Not because I need it, it' s just because I want to have it.:smileyvery-happy:
But why is it that way, just because I use an bond option the NAS won' t shutdown? In my opinion these features are not good implemented.
You are right. Until yesterday this "power timer" option was checked. Now I will try if this option was the case.
Best regards
Kalle
Kalle13
Apr 18, 2016Tutor
I have tried it with the unactivated power option but no success.
It won' t shutdown properly.
Best regards
Kalle
- StephenBApr 18, 2016Guru - Experienced User
FWIW, forcing the power down by removing the power cord is not ideal, there is some risk to your data every time you do it.
Does your switch support LACP? If it does, you would have needed to set it up on the switch.
Either way, I suggest you do a test w/o the bond, and at least determine if removing it resolves the problem (or not).
- Kalle13Apr 18, 2016Tutor
Hi StephenB,
my switch supports LACP and I've configured it and the NAS that. But because of the error I changed the bond mode to ALB.
Yes, to unplug the power cable is absolutely not he ideal solution!Thank you for you advise, I will change my setting and look if somtehing will change.
Best regards
Kalle
