PeteCresswell
Jul 02, 2025Follower
My ReadyNAS Ultra 6 Replecement?
My ReadyNAS Ultra 6 has gone offline - as in unavailable on the LAN - hopefully just because of a LAN board malfunction. Assuming all 6 drives are intact, is there another box I could buy and have th...
Rottenweiler
Jul 04, 2025Guide
Does the Ultra have dual ethernet ports? Might try the other one (can't hurt to try). Also IF you had recently adjusted settings in the network tab you MAY be able to recover by doing a OS re-install from the boot menu which will reset network settings to defaults (will also reset the password just FYI). Probably safest to do that after removing all your data disks and installing a blank/new or wiped scratch disc.
