viperhansa
Jan 28, 2018Virtuoso
My system volume is filling up with files "chunk-000xxx"
As stated in Subject. My md0 went from stable 38-45% to 67% over night. Did an mount on the system volume and checked and found lots och files named chunk-00001 and so on. Is it safe to delete tho...
- Jan 29, 2018
wrote:Can i remove those chunk files since they are old dates?
Yes.
Second: i forgot how to access disktests and will my data be altered or destroyed if i run them?
Click on the settings wheel for the volume (on the volume tab). The tests aren't destructive (unless of course disks fail when they are run).
There are several maintenance functions in there (defrag, balance, scrub, disk test). You might consider setting up a regular schedule to run them. I run each of them once every 3 months.
viperhansa
Jan 29, 2018Virtuoso
Thanks for the answer.
Edit:
Checked the smart info on all drives and that looked ok to me:
Device: sda
Controller: 0
Channel: 0
Model: WDC WD40EFRX-68N32N0
Serial: WD-WCC7K7PZ7DY8
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 7814037168
Pool: data
PoolType: RAID 5
PoolState: 1
PoolHostId: 33ea52d3
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 35
Start/Stop Count: 66
Power-On Hours: 4318
Power Cycle Count: 17
Load Cycle Count: 61
Device: sdb
Controller: 0
Channel: 1
Serial: WD-WCC7K2EFJXUF
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 7814037168
Pool: data
PoolType: RAID 5
PoolState: 1
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 36
Start/Stop Count: 77
Power-On Hours: 4301
Power Cycle Count: 16
Load Cycle Count: 72
Device: sdc
Controller: 0
Channel: 2
Serial: WD-WCC7K0XY95Y2
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 7814037168
Pool: data
PoolType: RAID 5
PoolState: 1
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 35
Start/Stop Count: 76
Power-On Hours: 4300
Power Cycle Count: 15
Load Cycle Count: 71
Device: sdd
Controller: 0
Channel: 3
Serial: WD-WCC7K5ZRZUCT
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 7814037168
Pool: data
PoolType: RAID 5
PoolState: 1
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 36
Start/Stop Count: 74
Power-On Hours: 4275
Load Cycle Count: 68
Device: sde
Controller: 0
Channel: 4
Serial: WD-WCC7K2JCKHP7
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 7814037168
Pool: data
PoolType: RAID 5
PoolState: 1
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 37
Power-On Hours: 2759
Power Cycle Count: 11
Load Cycle Count: 59
Device: sdf
Controller: 0
Channel: 5
Serial: WD-WCC7K1UF7A0C
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 7814037168
Pool: data
PoolType: RAID 5
PoolState: 1
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 36
Power-On Hours: 2746
Power Cycle Count: 9
Load Cycle Count: 63
// Hans
Jan 29, 2018Guru - Experienced User
Yes.
- viperhansaJan 30, 2018Virtuoso
Only have this to choose from...
Edit: found it, i have to make an scheduled event for disktest..
Deleting my chunk files got me back to comfortable 45% usage on system root again.
regards
// Hans
