Exkal
Jul 12, 2017Aspirant
My volume is gone.
Hello there, I have an issue with my ReadyNAS104 Netgear. First I noticed that I couldn't access my data so I went to the admin page through Google Chrome. As soon as I open the tab I get...
jak0lantash
Jul 12, 2017Mentor
Ok. Let us know.
The configuration of the shares/volumes can be a factor. So if you have the same config on both NAS, then it could be a reason.
Exkal
Jul 13, 2017Aspirant
After two days trying (and failing) to contact Netgears support we decided to destroy the volume and create it again from scratch.
We need to start making backups right now and it is impossible to contact them despite the fact that we are willing to pay the support fee.
Is there any way we can find out what was causing the problem with our volume? I'm afraid it can happen again.
- StephenBJul 13, 2017Guru - Experienced User
Did you download the logs before you destroyed the volume?
