aguden_guden_co
May 05, 2014Luminary
NAS Not on Explorer after Upgrade
I upgraded my 2 ReadyNAS NV+ boxes and after the upgrade, I see both devices in the right panel of Explorer (W7) under storage but on the left panel under Network they have both disappeared. They wer...
May 05, 2014Guru - Experienced User
Whether the NAS shows up in explorer seems hit-or-miss. Different computers on the same network don't always behave consistently, even if the OS and the network settings all look matched.
If for some reason it doesn't stay "fixed" there is a pretty simple workaround- which is to put suitable shortcuts on the desktop, and use those instead.
