ndverge
Feb 16, 2016Aspirant
NAS not showing under Network again after update to 6.4.2
I recently updated the firmware of NAS device. after update, the NAS device not visible on the network. But I can type the name on the run command and access. But i want the nas device to be visible...
- Feb 18, 2016
I just switch off the and on our 8-port switch. then the NAS drive is visible to all the computers in the network. thans who supported me.
Feb 16, 2016Guru - Experienced User
ndverge wrote:
I think its better to downgrade to 6.4.1 again.
You certainly can. It might not help though.
ndverge
Feb 17, 2016Aspirant
You are saying that even if i downgrade the firmware, the problem will be remained still?
- mdgm-ntgrFeb 17, 2016NETGEAR Employee Retired
No, he's saying that it is a possibility that it might remain. You can try downgrading to 6.4.1 and find out, if you want. Let us know of the outcome.
- ndvergeFeb 17, 2016Aspirant
I downgraded. but no any chance to win the war. Still the NAS device is missing in the network list.
what to do?
- StephenBFeb 17, 2016Guru - Experienced User
If this is with Windows 10, I think there might be some fixes coming from Microsoft (at least I recall seeing a post to this effect on another thread).
