InterClaw
May 31, 2015Aspirant
NAS not starting any services #25220444
I had a hard time coming up with a good subject for this problem, since I don't really know what's wrong and how to describe it. Here's the story: Suddenly I noticed that CIFS was not behaving norm...
Jul 01, 2015Guru - Experienced User
I believe it started with "synchronizing", then "compacting (deep)" and "pruning versions (deep)". There was a progress bar, with % completion. In my case it took a very long time (~10 days). I think it is a background task, and when it found stuff to backup it would switch over to the normal backup progress.
InterClaw wrote: Yeah, the compact button does not seem to do anything at the moment. Did you get some sort of progress bar when you did this?
