InterClaw
May 31, 2015Aspirant
NAS not starting any services #25220444
I had a hard time coming up with a good subject for this problem, since I don't really know what's wrong and how to describe it. Here's the story: Suddenly I noticed that CIFS was not behaving norm...
Dewdman42
Sep 03, 2015Virtuoso
I don't know how well this will work, but I just moved /usr/local/crashplan to /c/.crashplan and then created a sym link to it:
ln -s /c/.crashplan /usr/local/crashplan
Crashplan seems to be working ok that way
I did the same thing for the /tmp dir, moved it to /c/.tmp/ and sym linked to it. That one I am not as confident I won't run into some strange problem sooner or later, but I'm trying it for a while.
This should prevent either /tmp nor /usr/local/crashplan from ever filling up the root partition again.
Sep 03, 2015Guru - Experienced User
I moved the cache by changing my.service.xml (look for <cachePath>) but left the rest alone.
If /c/ couldn't be mounted you might have some issues running w/o /tmp. So I'm not confident in that one either.
It sounds like you ran out of memory?
- Dewdman42Sep 03, 2015Virtuoso
Yea i put tmp back.. I will just live with that one. but having /usr/local/crashplan sym linked to somewhere under /c is fine by me and I won't have to worry at all about any of crashplan's caching, logs or other things. I think it works either way. Most of my other apps like plex and so forth all install under /c/. I think crashplan should have also.
There is supposedly a way to edit the run.conf file under /usr/local/crashplan/run/run.conf, and you can add a -D option to specify an alternate tmp file location for java to use while running crashplan. I tried it once, but didn't work and didn't have time to try further.
Djava.io.tmpdir=/c/tmp
Something like that.
- StephenBSep 04, 2015Guru - Experienced User
I tried that briefly when Crashplan ran out of memory a few months ago. At least I set up a crashtmp folder on C. But I must have undone it, because its not in run.conf. I wasn't seeing many files there anyway - and the real issue was crashplan restarting all the time, and failing to back up. Its resolved now (crashplan did take the support case even though I was running headless).
I see no risk to linking the main crashplan directory, and it also lets you look at the logs w/o needing ssh.
I suggest setting the retention for deleted files on CrashPlan central (instead of leaving it at the default "never"). Then try consolidating the archive to reduce the storage there. Deduplication memory requirements scale with the archive, not with the local store.
I also set deduplication to minimal and compression off. Not sure if that helps memory or not. You can't go above ~3.5 GB for crashplan, no matter how much memory you have in the NAS - it only runs on the 32 bit jvm.
