InterClaw
May 31, 2015Aspirant
NAS not starting any services #25220444
I had a hard time coming up with a good subject for this problem, since I don't really know what's wrong and how to describe it. Here's the story: Suddenly I noticed that CIFS was not behaving norm...
Sep 04, 2015Guru - Experienced User
I upgraded my memory also.
The Crashplan cache is 1-2 GB so it will fill up the OS partition. But crashplan doesn't normally put stuff in \tmp.
Dewdman42
Sep 04, 2015Virtuoso
crashplan doesn't directly, but java does, which is used to run crashplan. Java puts a tmp file of some kind into /tmp.
but as I said earlier there is supposedly a way to edit /usr/local/crashplan/run/run.conf and you can assign an alternate standard tmp file location to be used when crashplan is launched through java.
See this wki page about half way down under the section "waiting for backup"
https://wiki.archlinux.org/index.php/CrashPlan
But generally I think i agree, the big culprit here is the crashplan cache filling up the root partition very easily. Though when I was looking into this, my /tmp dir was full with 1.3GB worth of junk of some kind also, so I would like to understand more about how to keep my /tmp file empty or run some kind of cron job that will routinely clean it out, but I'm not sure how to do that safely.
- StephenBSep 04, 2015Guru - Experienced User
Right now I am seeing
-rw-r--r-- 1 root root 2124086 2012-07-23 21:54 AirVideoServerLinux.jar
-rw-r--r-- 1 root root 226 2010-10-29 16:35 airvideo.service
-rwxr-xr-x 1 root root 14716 2010-05-06 02:08 bon_csv2html
-rwxr-xr-x 1 root root 3623 2010-05-06 02:08 bon_csv2txt
-rwxr-xr-x 1 root root 47608 2010-05-06 02:07 bonnie++
-rw-r--r-- 1 root root 2 2010-05-06 09:37 coef.txt
-rw-r--r-- 1 root root 215111 2014-06-20 06:40 config.zip
-rw-r--r-- 1 root root 9 2015-09-04 10:00 .dhcp_server
-rw-r--r-- 1 root root 1119723 2012-05-15 05:05 dl
-rw-r--r-- 1 root root 1104638 2012-05-15 05:10 dl2
-rw-r--r-- 1 root root 0 2015-09-04 04:10 errors_004.log
-rw-r--r-- 1 root root 0 2015-09-04 05:10 errors_005.log
-rw-r--r-- 1 root root 0 2011-09-30 18:50 group.14830
-rw-r--r-- 1 root root 0 2014-01-07 19:10 group.31151
drwxr-xr-x 2 root root 4096 2015-08-22 09:59 hsperfdata_root
-rw-r--r-- 1 root root 37282632 2010-10-29 16:35 jre1.6.0_20.tar.gz
-rw-r--r-- 1 root root 211 2011-02-09 16:24 readynas.properties
-rw-r--r-- 1 root root 511 2010-05-06 02:06 rm-share.pl
-rwxr-xr-x 1 root root 4587 2010-06-30 14:27 run_bonnie.sh
-rw-r--r-- 1 root root 53 2010-05-06 04:06 smb2.conf
-rw-r--r-- 1 root root 454 2010-05-06 04:06 smb.conf
-rw-r--r-- 1 root root 7 2015-03-19 20:32 .update_from
-rwxr-xr-x 1 root root 19888 2010-05-06 02:07 zcavI don't know where some of these files are coming from, but I don't see signicant space use.
- Dewdman42Sep 04, 2015Virtuoso
I'm glad for you. mine was 1.3GB. I deleted everything in there already so I can't tell you what it was. But it was a lot of numbered stuff and could have been created by anythin
crashplan creates some kind of jna file when being launched with java, but its not clear to me now whether that was significant or something else was in my /tmp dir sucking space from root partition.
Its really unfortunate the readynas doesn't have some auto housekeeping job to keep /tmp cleared out because the root parition is really not that big. At the very least, on startup it would be a good idea to empty it.
At the very least the UI should tell you how much space is used there. It would be very helpful.
