InterClaw
May 31, 2015Aspirant
NAS not starting any services #25220444
I had a hard time coming up with a good subject for this problem, since I don't really know what's wrong and how to describe it. Here's the story: Suddenly I noticed that CIFS was not behaving norm...
mdgm-ntgr
Jun 01, 2015NETGEAR Employee Retired
The cache was several hundred MBs. I removed it. Not sure why the change didn't stick.
1. There were a whole of files starting with jna and ending in .tmp in the /tmp directory. Did the change of /tmp directory for Crashplan stick?
2. You can delete files from there, though some of the files in there may be in use by an application at the time e.g. if a Frontview backup job is in progress you shouldn't delete the temporary backup job log for that backup.
3. You should periodically check the fullness of the OS partition and take steps to find out what's going on if the usage is unexpectedly high.
4. No the OS partition is fixed at 4GB in size.
nosstrannel
Oct 10, 2015Aspirant
Hi!
I have the exact same problem with my ReadyNas Ultra 2 and created a ticket, 25880935.
I would really really appreciate som help from you :)
I cant connect to my ReadyNas with SSH anymore so I cant do just about anything about my problem...
Reinstalled OS, and now the volume settings shows nothing in the webinsterface (which is the only accessble service on the device...)
but I HOPE the data is still on the disks..
Thanks in advance!
Markus
- StephenBOct 10, 2015Guru - Experienced User
nosstrannel wrote:
Hi!
The ultra is running crashplan???
- nosstrannelOct 10, 2015Aspirant
Yes it is. It actually answers on port 4242 and 4243 and the admin-web gui but thats about all for now..
Has been running Crashplan for quite a long time actually. Maybe 2 years or so.
It is an Intel x86 ReadyNas
Best regards
Markus
Read through this: https://community.netgear.com/t5/Backing-up-to-your-ReadyNAS/Crashplan-JRE-update-needed/td-p/985781
Netgear can clean up the OS partition remotely.
Or if you google, you can find telnet instructions, mount the OS partition, and delete the 1*.* files/folders in /usr/local/crashplan/upgrade
