InterClaw
May 31, 2015Aspirant
NAS not starting any services #25220444
I had a hard time coming up with a good subject for this problem, since I don't really know what's wrong and how to describe it. Here's the story: Suddenly I noticed that CIFS was not behaving norm...
Oct 11, 2015Guru - Experienced User
Dewdman42 wrote:
Either way. But at least if cache is not on the OS partition then the system won't lock up
Truthfully it would with the 4.4.1 upgrade issue. The files filling the OS partition are in /usr/local/crashplan/upgrade.
But I think that is a one-of bug, hopefully not a mistake they will repeat.
nosstrannel
Oct 12, 2015Aspirant
Thank you so much for your help!
The ReadyNas is now up and running.
First I deleted the upgrade-folders for crashplan.
Then I Moved the Crashplan folder to the datavolume and upgraded Java so that Crashplan could upgrade.
Hoping the Nas will stay running for a while :)
Best regards
Markus
