Fandango522's avatar
Fandango522
NAS offline - ReadyNAS 104 with firmware 6.5.1
Hi all,
I am having an issue tht I cant seem to solve. Today I updated Nas to latest firmware and also updated plex media server to latest version since then the Readycloud page is showing offline with no devices discoverable. I used Raidar and disks are fine with green lights for everything. I can access the files via the browse option witin Raidar.
The only app I use is Plex and Plex finds the server and shows files but when i attempt to open its very slow to load and warns me the connection is slow, finally the power button causes the system to freeze on system shutting down which causes me to either pull the plug or shutdown via setup.
Any help would be appreciated and I have downloaded logs.
Thanks
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Can you send the logs in (see the Sending Logs link in my sig)?
      • Fandango522's avatar
        Fandango522
        Appoligies i forgot the  ReadyNAS forum moderator within subject line but hopefully you have it.
  • Following your instructions, I now have access to both admin and ready cloud. On opening ready cloud I receive an error message 6001010106.
    Improvement on last position, any one know the error code?
    Cheers
      mdgm-ntgr
      RAID doesn't equal backup. The protection against a single disk failure from e.g. X-RAID is great, but there are other less common problems than a disk failure that may be run into. See e.g. Preventing Catastrophic Data Loss
      I don't know what causes this error code.
        Fandango522
        Great information and thanks for the advice! Backup dive it is.
        I can live with the code since I can now acess the drive with ease and will hopfeully figure out the problem with the Nas and plex server communicating.
        Thanks again for your time.
  • Hi Brian , no I downgraded to 6.5 beta from previous post. Netgear email is the one I use to login to the community.
    Thanks
    Mod Edit: Please don't post your email addresses publicly. Send a PM if asked for something like this or if it's the same one you use to login to the community mention that.
    • BrianL2's avatar
      BrianL2
      Hi Fandango522,
      Have you started backing up your data? If you want us to fix the ReadyCLOUD error you got on the web portal, the Firmware should be 6.5.1. Update this thread if you want to proceed.
      Kind regards,
      BrianL
      NETGEAR Community Team
ProSupport for Business
