firefly_242
May 01, 2018Aspirant
NAS Pro Pioneer Edition on OS 6.9.3 freezes/ network dropout
Hi,
Update from RAIDiator-x86-4.2.31 to OS6.9.3 went smooth and am happy with the new OS.
However, my system sometimes drops out or freezes. The interval between them ranges from 1 day to 16 days...
mdgm-ntgr
May 01, 2018NETGEAR Employee Retired
You can send in your logs if you like (see the Sending Logs link in my sig). Ideally logs should be downloaded ASAP after running into the problem.
firefly_242
logs shared. thanks for looking into this.
- mdgm-ntgrMay 01, 2018NETGEAR Employee Retired
smart_history.log indicates a current pending sector on a few of your disks.
Can you test your disks e.g. using WD Data LifeGuard Diagnostics for WD disks or SeaTools for SeaGate disks?- firefly_242May 02, 2018Aspirant
thanks for the fast reply. will have to buy an enclosure first to be able to connect the drive to my laptop.
Will update once drives are tested.
- firefly_242May 09, 2018Aspirant
Hi,
Took awhile to run WD Data LifeGuard Diagnostics extended test on all 6 HD's, but finally done. All 6 HD's passed the extended test.
So, I assume that means the issue is not with the HD's.
Any idea what to check next?
Thanks
- Jan 17, 2024Retired_Member
