Irfanshaik026
Dec 15, 2025Follower
NAS RN 214 showing data degraded error
As my NAS RN 214 suddenly showing data degraded error on screen of device and it is blinking, since login in the NAS and found one of the hard drive showing offline ( no green color ) . Kindly help w...
Dec 16, 2025Guru - Experienced User
Irfanshaik026 wrote:As my NAS RN 214 suddenly showing data degraded error on screen of device and it is blinking, since login in the NAS and found one of the hard drive showing offline ( no green color ) . Kindly help with suggestion for further solution.
Generally this is a result of a disk failure.
Download the full log zip file from the logs page. You can see SMART statistics in disk_info.log, and also see disk errors in systemd-journal.log.
If you aren't seeing clear signs of a disk problem, then let us know.
Best options for replacement are NAS-purposed drives (WD Red Plus, Seagate Ironwolf, Toshiba N300 series) or enterprise class. Don't use desktop drives, as many are now SMR and don't work well with ReadyNAS.
