BaGRoS
Apr 07, 2022Aspirant
NeatGear NV+ V2 not mounting /dev/c/c
Hi After command: root@nas-JohnyB:~# mount -o ro /dev/c/c
mount: special device /dev/c/c does not exist ?! Why? Any help? root@nas-JohnyB:~# sudo fsck
fsck from util-linux-ng 2.17...
Apr 07, 2022Guru - Experienced User
Are you booting up normally?
Are you seeing issues when you run dashboard?
Is RAIDar telling you anything useful about the NAS health? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
BaGRoS
Apr 09, 2022Aspirant
I try reinstalled firmware but is some error, see attached picture.
- StephenBApr 09, 2022Guru - Experienced User
Maybe try rebooting.
It would also be useful to download the full log zip file, and see if there are clues in there on why the data volume isn't mounting.
Was there a power loss of some kind? Loss of cached writes can result in an out of sync RAID array that won't mount.
- BaGRoSApr 09, 2022Aspirant
I pull out Disc no 1 and:
Why Disk 1 is Dead if is pull out completely???
Again, I suggest downloading the full log zip. Look for health of all disks in the smart logs. Also look in system.log and kernel.log for errors related to disks, RAID, and the file system.
