bertschj
Jul 10, 2019Aspirant
Need full rebuild - 3 of 4 drive degraded
A friend of mine has ReadNAS - not sure what model but was purchased in 11/2014 and has 4x3tb drives. - they noticed front panel says volume degraded - could *not* access web interface - could ...
- Jul 11, 2019
Degraded means one or more drives on your array failed and it entered this mode to be able to continuously use the array. This mode however, you might experience a slow performance on the array hence degraded like having issues accessing the interface etc, but data should be accessible.
Were you able to backup the data while it's accessible?
If you will insert the 4 new drives on the NAS it will be recognized as a new system and will perform a reset to create a new volume and system on the disks. Old configurations and shares will not be on this volume.
You can either Clone the old drives or use 3rd party software like ReCLAIMe to recover data from the disks or Purchase a Data recovery service either from NETGEAR or 3rd Party service providers.
If you have backup of your data then it would be easy to get the new drives to setup and then transfer the data to it.
Marc_V
Jul 11, 2019NETGEAR Employee Retired
bertschj
Jul 11, 2019Aspirant
Thanks - appreciate the response
