fremske
Nov 03, 2016Guide
Need help: System volume root's usage is 100%
Dear community, I have serious issue with my ReadyNAS 102. Currenrly my ROOT volume usage is 100%, resulting in not being able to access the Frontview and all kind of instabilty in the accessibi...
kohdee
Nov 03, 2016Administrator
According to this, your root volume is only 65% full.
/dev/md0 4.0G 2.4G 1.4G 65% /
The RN102 uses ext file system for the volume and not btrfs, so not totally sure what would be causing your root volume full messages.
If your "MEDIA" volume is less than 5%, you need to consider expanding that array or deleting data, as per the error message.
If you use RAIDar 6, you can tap up to 6 or 7 times on your ReadyNAS and it will activate remote support options. Once you enable yours, send me your port number and I'll look at your system.
