armornone
Apr 23, 2012Aspirant
Need RAIDiator-4.1.3, how do download
Hello How can I download RAIDiator-4.1.3? I have a very old Readynas. I don't even know what model number it is but its looks like an X6. Anyway, it uses a compact flash card which I suspect is 64M...
armornone
Apr 27, 2012Aspirant
mdgm wrote: Can you try 4.1.4?: http://www.readynas.com/download/RAIDiator/archive/4.1.4/RAIDiator-4.1.4
4.1.3 is larger than 4.1.4 and both are larger than 55MB.
If necessary ou can try removing the CF and writing 4.1.4 to the entire CF using rawrite or ntrawrite (depending on which version of Windows) or dd on Mac/Linux. If it still won't work try a 128MB or greater capacity CF card.
Do you need the newer firmware in order to suppose 2TB drives?
Thanks
