MaxPrimal
Apr 23, 2013Aspirant
Netgear Duo storage capacity
Hi. I have bought a Netgear Duo with 2x1tb hard drives installed and I want to ask a dumb question. The NAs is up and working, RaidR reports both drives are in, working and available. So why is ...
MaxPrimal
Apr 24, 2013Aspirant
StephenB wrote: You aren't doing the factory reset. Check page 16 of your hardware manual - here: http://www.downloads.netgear.com/files/Duov1_NV%2Bv1_HW_en_06Dec11.pdf If that doesn't work, put the disk in a PC and delete the partitions there.
Again, you want to do that with one disk installed.
Okay got a problem again, sorry.
I installed one drive and it said it created a partition which was fine and all seemed. Okay. After it had finished and I had left it another 5 mins, I turned it off and put in the other drive.
Now I get the following told that I only have a single drive. I cannot use the URL tag here for some reason but if you want to see pics of what the NAS is saying copy and paste the image links below:
http://i836.photobucket.com/albums/zz281/Yoshi15782/NAS/Untitled.jpg
http://i836.photobucket.com/albums/zz281/Yoshi15782/NAS/Untitled2.jpg
http://i836.photobucket.com/albums/zz281/Yoshi15782/NAS/Untitled3.jpg
These also show what Raidr is reporting.
Does this mean i need to take the drives out (again) but this time wipe them using my PC or is this a sign of another issue I am having?
Sorry for so many questions but this is all over my head and I am struggling here sadly.
Thanks
Max
- Sep 02, 2016Retired_Member
