MaxPrimal
Apr 23, 2013Aspirant
Netgear Duo storage capacity
Hi. I have bought a Netgear Duo with 2x1tb hard drives installed and I want to ask a dumb question. The NAs is up and working, RaidR reports both drives are in, working and available. So why is ...
Apr 25, 2013Guru - Experienced User
Did you create a volume using the second disk drive? See page 20 of your software manual: http://www.downloads.netgear.com/files/ ... 6Dec11.pdf
If the disk isn't shown, remove it and re-insert it with the NAS running (e.g., don't power down).
- Sep 02, 2016Retired_Member
