Jefrison
Feb 06, 2023Follower
Netgear NAS 5Gbps to Dlink 10G SFP+
Hi, In 2019 we bought ReadyNAS 424, which has 2 Ethernet ports of 5Gbps Speed. Now I need to connect my NAS with Dlink DGS-1510-52X Switch (which has 4 10G SFP+). Is it possible to connect my NAS to...
schumaku
Feb 07, 2023Guru - Experienced User
Confused where the impression comes from the 424 has 5 Gigabit or MultiGig ports.
The basic models used to be equipped with a pairs or four copper Gigabit Ethernet ports. Bigger models like the ReadyNAS 4220S used to be equipped with dual 10Gbps LAN Copper 10GBase-T or the ReadyNAS 4220X with dual 10Gbps LAN Optical SFP+
Industry standard SFP+ modules are perfectly fine, so are 10 GbE over fiber or 10GBaseT modules.
