Amorim_Jose
Jul 25, 2020Aspirant
NETGEAR NAS214 SLOW ON SEARCH BY TERMS
HI, I recently bought the ReadyNas 214 to make backups of my job files and acess to then in my house or even outdoors. I have four 3tb sata disks in raid5 and creat a shared folder "work" whe...
Amorim_Jose
"There is a file search feature in the NAS admin web ui"
Where can o find this??
I think you dont understand... I access the files and the search by Ethernet on the dá-me space...
The information of the disks I can tell u later because I dont have the nas with me right now
Jul 25, 2020Guru - Experienced User
On the first page of the NAS web ui.
I totally understand this. File search over ethernet is much slower than file access over ethernet. Folder browsing is also slower than copying files.
Generally speaking, it is best to use NAS-purposed drives (or enterprise drives) in your NAS. What you want to avoid is drives that use SMR technology. But using SMR drives won't slow down read speeds (or search). They slow down write speeds (often dramatically).
