HansPopp
Jun 13, 2024Aspirant
Netgear ReadyNAS 214 won't boot past 99% and Shares not accessible
My ReadyNAS had been a bit slow in reacting and bringing up files so I looked at the screen and saw "booting 99%" and "clamav-clamonacc". After attempting to access the device via RAIDar I saw that...
HansPopp
Thanks for the reply StephenB.
The NAS brings up an error when I try to download the log files.
When I reboot in OS reinstall mode, I can see the following error on the admin page:
"Please remove inactive volumes #1 2 3 to use your drive." or similar
Jun 14, 2024Guru - Experienced User
You must mean recovery mode, not OS reinstall mode. Don't remove any volumes, as that will destroy data.
What error are you getting when you download the log files?
Are you seeing any indication on the logs page that the root is full?
- HansPoppJun 14, 2024Aspirant
Hello Stephen,
I dont know of any recovery mode in the ReadyNAS 214. The OS reinstall resets the firmware back to "safe" version in the flash memory according to the manual. The OS reinstall option is the only one that has let me access the Admin page to troubleshoot, but you can see even here that some corruption is present. It also resets the admin password back to default.
I'll upload some screenshots of the errors I receive when I access the Admin page after booting in OS reinstall mode. The logs were also not accessible/downloadable, but I was just able to download them. Previously the dbbroker had brought up an error. How can I upload them? This page only allows PDF, GIF, PNG and JPG.
Thank you so much for your help!!
Hans
- StephenBJun 14, 2024Guru - Experienced User
The "Safe" mode is what I am talking about. OS reinstall isn't the only thing that can trigger it.
Don't post them publicly, there is some privacy leakage when you do that.
If you want me to take a look at them, you can upload them to cloud storage (dropbox, google drive, etc) and send me a private message (PM) with a download link. Make sure the link permissions are set so anyone with the link can download.
You can send the PM using the envelope icon in the upper right hand corner of the forum page.
