Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
vandermerwe
Oct 07, 2014Master
If it was the disk in slot 1 of the duo and the disk is not faulty then you should be able to read it using this, which needs to be installed on a PC. The drive obviously will need to be connected to the PC, perhaps with a USB caddy.
http://www.diskinternals.com/linux-reader/
If you get hold of the data, make sure you have a backup plan in the future.
