Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
vandermerwe
Oct 07, 2014Master
I have just noticed that your disk was not in Raid, did you have it set as jbod?
The 2 3tb drives, are those new drives for your new nas or are these the ones from the duo?
I am not sure if linux reader would not work, it works with the sparc units but does not seem to work with the intel units.
I'm not sure about the duo v2, perhaps StephenB has tried it.
