Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
Hofmann1
StephenB wrote: Hofmann, if you have been using 3 TB disks then you must have a Duo v2 or an ultra/pro 2. If so, linux-reader won't work (so don't try vandermerwe's suggestion right now).
Can you check this guide? http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/ You can also copy the model number off the label (something like RND2000-200) and tell us what that is.
Your NAS uses the linux ext file system. The data volume is also formatted as ext, but its built on top of RAID, Windows won't access it. FYI, Windows won't see any partitions from any NAS that is built on linux. Almost all of them are.
I'm positive that my NAS is a v1, it's atleast 3-4 years old and identical to the v1 layout portrayed in your linked guide. The discs are just a few months old, and only one of them ( "disc 1" ) has ever been insterted into the ReadyNAS. This is also the only disc containing the data i want to salvage.
vandermerwe wrote: I have just noticed that your disk was not in Raid, did you have it set as jbod?
The 2 3tb drives, are those new drives for your new nas or are these the ones from the duo?
I am not sure if linux reader would not work, it works with the sparc units but does not seem to work with the intel units.
I'm not sure about the duo v2, perhaps StephenB has tried it.
I've never set up RAID on these discs, basicaly just plug and play so i take it that they end up as JBOD this way.
Caddy? No, i drive a Volkswagen.
vandermerwe wrote: perhaps with a USB caddy.
/golfclap
