Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
Hofmann1
Oct 08, 2014Aspirant
You're right, it is a v2. RND2000 v2. But the layout of the back is sill identical with the depicted v1 model in the beforementioned link.
If so, it should be able to handle 3TB discs. Remember, i've only ever had 1 of my 2 3TB discs in the readyNAS. I'll try the linuxreader when i get home tonight.
